Author Topic: Gutted - my 256 calipers are borked  (Read 967 times)
Offline jaybv6
  • 03 Mk4 GTTDI PD 150
« on: 28 January 2007, 14:08 »
That is unless I can sort them out.  I bought a 256mm brake set-up from a 16v and was assured it was sound.  The calipers need a clean and the pistons seem ok however the bleed nipples are rusted in the caliper.  Damn.  Have tried heating them up to try and remove them, nothing.  My mate is gonna have a go and then looks like I will have to spend even more on re-con'd calipers.
Anyone got any advice on how to rectify this?
Offline systemseiko
Re: Gutted - my 256 calipers are borked
« Reply #1 on: 28 January 2007, 15:48 »
Remove the pistons carefully not to damage seals etc,  take it to yout local engineering shop and get them to heat the nipples and remove them,  it doesn't matter if they break as most engineering shops have access to easi-outs,  a device similar to a tap which is screwed in anti-clockwise and then screwed out cw,  they should have no bother geting this out and it will save you time and hassle,  expect to pay £10.00 a caliper,  if you have to resort to this it is ideal to replace both pistons seals roughly around £13.00 each from Vw
If it is a 90 mph per hour wind and you drive your car at 90mph downwind, if you stick your head outside would you feel the wind?
Offline monzablue16v
« Reply #2 on: 28 January 2007, 21:34 »
Try using some plusgas that stuff saved me a lot of swearing at the weekend if not then as above get them engineered :(
Offline jaybv6
« Reply #3 on: 29 January 2007, 09:52 »
What does the Plugas do?  What is it?
