Author Topic: mk2 speakers  (Read 4078 times)
Offline SLIM-DUB
mk2 speakers
« on: 27 January 2007, 13:36 »
can anyone help me with the sizes of speakers that are in a mk2 and if anyone has used a certain make that sound really good,whether they were cheap or costly,just want some advice as my golf needs the sounds sorting out and just wanted to know some views so i can choose my path! many thanks in advance!  :wink:
<br www.vwwold.co.uk<br />PIMPASAT 20v se
Mint Finish!
sacvwgolf
Re: mk2 speakers
« Reply #1 on: 27 January 2007, 17:04 »
there should be some rear speakers i think which are 6X4 but the front i don't know some mk2 have speakers in the door cards plastic trim at the bottom and tweeters in the dash but some only have speakers in the dash.
Offline SLIM-DUB
Re: mk2 speakers
« Reply #2 on: 27 January 2007, 18:11 »
thanks bud,mines got some supposed mac audio in the doors,gotta have a full re-fit of my stereo tho as im not sure that even half of what i got are working!  :shocked:
Mint Finish!
Offline Uruk Hai
Re: mk2 speakers
« Reply #3 on: 27 January 2007, 20:05 »
As said the rears are 6 x 4 and the fronts door pods hold 5.5 inch or 13 cm
Offline tommk3cab
Re: mk2 speakers
« Reply #4 on: 27 January 2007, 20:10 »
the dash ones by the window are a well dodge size, are they 10 or 8cms? correct me if im wrong, but look bigger than they are anyway, some of my mates have bought 13cms and had some fitting problems. The mk3s have that pretty much sorted though as they (or mine at least) have factory fit tweeters in there, which are going good so far, wouldnt want to blow them though as fitting new ones (or disconnecting the old ones even!) will be quiet a task ( no screws visable! )
« Last Edit: 27 January 2007, 20:11 by tommk3cab »
Offline Uruk Hai
Re: mk2 speakers
« Reply #5 on: 27 January 2007, 22:21 »
What problems have your mates had with the fitting of 13cm speakers ?
Offline tommk3cab
Re: mk2 speakers
« Reply #6 on: 27 January 2007, 22:52 »
in the dash tweeter bits in a mk2, they are like 10 or maybe even 8 cm, 13cms will fit (just!) but it mishapes the dash plastic and can snap it. im pretty sure this was the case in the mk2s, best way is to take them out and see, the door speakers im not too sure of, never seen any at all!
« Last Edit: 27 January 2007, 22:54 by tommk3cab »
Offline SLIM-DUB
Re: mk2 speakers
« Reply #7 on: 28 January 2007, 09:12 »
cheerz for all the input people! been looking about for some 6x4's and found a good set of jbl's for 18.99 on the bay! as for the doors,i will be taking em to bits today to see if they are  connected so will get some measurements and let u know what the crack is with them!  :wink: thanks again!
Mint Finish!
Offline Uruk Hai
Re: mk2 speakers
« Reply #8 on: 28 January 2007, 12:37 »
Apologies for hijacking the thread, Tom when you said your mates had probs fitting 13cm speakers I thought you meant in the doors ! I've never seen that size in the dash and imagine it would be a nightmare to fit oversize speakers into such a small space, the correct size for the dash speakers are 3.5 inch and in my first Golf I fitted these :-
http://www.caraudiodirect.co.uk/infinity-reference-3012cf-p-4542.html?cadid=87b757f8f2c503b6537dd4d8985157cc
They were a tight fit and I had to solder the connections as there wasn't enough room for spade end connectors, but the fuss was worth it as they sounded way better than the crappy standard ones  :smiley:
Offline SLIM-DUB
Re: mk2 speakers
« Reply #9 on: 28 January 2007, 14:36 »
no worries bud,they look sweet and reasonably priced too! trying to make the gti mine at the mo,having got it 2 wks ago,i still havent really done anything to make it mine yet,but im trying today!  :wink:
Mint Finish!
