Author Topic: White smoke on Startup only - GTI Digi Mk2  (Read 7986 times)
Offline DarnPB
  • Formerly Darnpistonbroke
Re: White smoke on Startup only - GTI Digi Mk2
« Reply #10 on: 24 January 2007, 23:20 »
Update on last reply.
¨Constant white smoke may indicate blown head gasket and you are letting water into the oil system.¨
Water can also be transfering directly from the water galleries to the combustion chamber via a damaged head gasket. This would also cause you to lose compression.
« Reply #11 on: 25 January 2007, 09:16 »
best way to do a compression test is to pull the ECU relay before you start, that way the coil will not be energised and the injectors wont spray fuel into the bores.
Offline Daxcossie
« Reply #12 on: 25 January 2007, 14:49 »
I suspect that it could be worn valve guide seals.  After 10 mins of running if sat in traffic for 5 mins or so and I then pull away it will puff white smoke on hard acceleration (foot to the floor).
How much will it cost for the guide seals to be changed in a Garage and should anything else be changed at the same time (I guess tappets) ?
<br /><br />Arranging Insurance cover for customers since 1975 " www.sheraton.uk.com "
Offline Ben Lessani
« Reply #13 on: 25 January 2007, 15:01 »
they'd charge you a small fortune, have to remove the head, replace head gasket, head bolts, then valves will need grounding in again,
at a guess, they'll charge you about 2.5 hrs labour to take the head off (if no problems are encountered), another 2.5 to rebuild it. £30 to lap the valves, new seals (dunno price), and then hg, and head bolts.
5hrs x £30 = £150
head gasket = £15ish
head bolts    = £15ish
lap valves    = £30
valve seals   = ??
i dunno, about £2-300 i reckon?
do it yourself - easy peasy!
Offline Daxcossie
« Reply #14 on: 30 January 2007, 11:18 »
Thanks for the info guys  :smiley:
I will continue with it at present as its still starting ok and once warmed up drives well.
If it gets worse,  I will then consider getting the valve seals done.
