Author Topic: heating (luke warm...cold)  (Read 2020 times)
Offline Stu M
« on: 20 January 2004, 19:17 »
hi i was wondering if anyone has had this problem before:
when car running and heating switch on hot, the air comming through it is only luke warm and then cold then wee bit warm even when temp gauge is half way.
no water leaks, im thinking heating matrix.
try and have a look at it friday.
thanks guys
golfvr6
Re:heating (luke warm...cold)
« Reply #1 on: 20 January 2004, 19:21 »
Try changing the by-pass valve, it is between the 2 hoses that go into the bulkhead next to the coolant expansion tank.
Offline Stu M
« Reply #2 on: 20 January 2004, 19:58 »
thanks ill have a look  :)
i just got this car going to by manual tomorrow
« Reply #3 on: 22 January 2004, 13:50 »
Worth checking the control flaps in the heater box as well, sometimes the foam rots away so preventing a good seal and there is also a small cog that can fall out.
Easy way to realign everything: put both sliders to the far right, move the flaps where they should be and reconnect it.
Offline danhock
« Reply #4 on: 22 January 2004, 16:05 »
Easy way to clear a blocked heater matrix.
Disconnect both hoses that go into bulkhead... Attached hose to one side (make sure heater is set to hot as it will open the vavle).
Spary into hose... If water comes out freely then its ok and the problem could be elsewhere (thermostat not opening for instance).
Did this recently on my girlfriends Micra.. Worked a treat!!
All opinions expressed in this mail are wholey owned by danhock and are not representative of golfgti.co.uk or it affliates.If you disagree with my comments please note that i do not give a f**k ?2005
Offline gti fly bye
  • VW MK4 GT TDI, ITS A SMOKEY ALTERNATIVE!
« Reply #5 on: 23 January 2004, 01:02 »
i had that problem, found my matrix was leakin, replaced it, still cold. i.ll try that valve me thinks!
also my temp gadge never gets past the 1st line(cold) when cruising, is this a cause?
BEAT ANY GTI (TOWING A CARVAN, UPHILL)
