Author Topic: heater only works on speed 3??  (Read 4418 times)
Offline posicarl returns
Re: heater only works on speed 3??
« Reply #10 on: 09 January 2007, 19:18 »
My Caddy blower works only on full blast (no3) but on all settings 1, 2 and 3.
Is this the same problem?
cheers.
Offline takethefifth
« Reply #11 on: 10 January 2007, 00:47 »
probably.
« Reply #12 on: 10 January 2007, 22:15 »
Terrific :undecided:
« Reply #13 on: 12 January 2007, 03:23 »
Well i would say 99% yes then.  The 1% is because i am not completely sure that a Caddy's internals are the same. Pretty sure they will be though.
« Reply #14 on: 12 January 2007, 12:17 »
tghe caddy internals are not the same, but they do have a resistor for the fan :)
To get to it, open the bonnet & remove the plastic scuttle cover, you'll see the fan & blower inlet.  Remove the 4 bolts holding the grill on, then unplug the resistor and remove the screws holding the bracket to the car.
At this point, its a good idea to spray the moving parts of the fan with some spray lube, silicone stuff works well.
