Author Topic: 2.0 16v ABF fault code  (Read 1198 times)
Offline raylee25
« on: 06 January 2007, 20:53 »
Just bought a VAG COM lead on E-Bay and installed it on my laptop, went out to the car to see if it would work. I only bought it because I was getting a misfire around 2000rpm. After changing the ECU relay, fuel pump relay, plugs, dizzy cap, arm, leads, coil. still no change.
So this is a copy of the fault code the vag com came back with:-
1 Fault code found
00513-Engine speed sensor (G28)
           27-10- Implausible Signal - Intermittent
What does this actually mean? and wheres the sensor located? Is it easy to change? and cost?
If this solves the misfire problem, it will be the best £25 I've spent
Thanks
Offline garfayliu
Re: 2.0 16v ABF fault code
« Reply #1 on: 07 January 2007, 11:38 »
Hi Raylee..
I had the same problem last year on my mk3 16v, it'll gradually get worse until the car is undrivable.
The part is around £80+VAT I think, maybe more depending on source.
The sensor is located at the front of the engine block, around the oil filter housing, might be a tough job to do because the ngine mount is in the way.
Offline eurosurplus
« Reply #2 on: 11 January 2007, 13:26 »
