Author Topic: exhaust hanger bracket  (Read 3293 times)
Offline Uku
« on: 30 December 2006, 22:09 »
anyone know where to get a rear exhaust hanger bracket for a magnex exhaust . a friend needs one , ive contacted magnex as im sure they do sell them on there own , but was curious if theres other places to source them?.
Offline hrf
Re: exhaust hanger bracket
« Reply #1 on: 30 December 2006, 23:41 »
Cheers Uku, thanks for asking about the bracket. I'll check back here for replies and queries.
I've just signed up and I am saddened to have missed user number 15,000 by just 2.
HRF!!
please use you're, your and they're, there, their and to, too and its, it's correctly:
Whilst you're crawling along in your Lada, they're flying there in their Learjet,
proceeding to down too many glasses of champagne from
its galley and commenting "Look down there, it's a skip on wheels".
Offline jase555
  • DUBS DONT DIE, THEY JUST GET LOWER!!
« Reply #2 on: 30 December 2006, 23:48 »
if the brackets aint too far away from the welded hook you could try turning the car exhaust bracket around. thats what i did with my scorpion.
regards
Offline Uku
« Reply #3 on: 31 December 2006, 17:30 »
no worrys m8 and welcome to the forums btw :) . ill let you know the price that magnex sell em for when they get back to me , and yes you can reverse the original bracket but it doesnt give that good a fit as ive done it before , the magnex one or similar places the backbox perfectly , ive emailed magnex with the part number of the bracket for a price.
Offline xxdansigxx
« Reply #4 on: 01 January 2007, 20:08 »
take the bracket to an exhaust place i have a very good place by me and im sure they will match the bracket up for you.....
should be alot less than magnex...
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #5 on: 02 January 2007, 12:02 »
I've purchased 2 of these in days gone by from Magnex direct and including P&P I'm sure it was around £15 each .....
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline hrf
« Reply #6 on: 02 January 2007, 19:59 »
I shall make a bracket up at my Local Garage. Thanks for your help!
However. The exhaust Uku kindly helped me out with is just the rear section.
I currently have a 1.6 carb'd. I'm going have to replace the front section with the GTi type which I have discovered is two sizes bigger.
HRF!!
Offline Uku
« Reply #7 on: 02 January 2007, 22:01 »
ill have a hunt round my shed , im sure i had a pipe reducer for magnex backbox's to fit non gti models lying around somewhere , if i find it ill email you and post it or somin. its a piece of metal tube that slides inside the end reducing it to required size.
« Reply #8 on: 03 January 2007, 12:15 »
I nicked a bracket off a ford escort, the one just in front of the rear beam from the model with the roundy bumpers:
Bit hard to see but was perfect for my backbox as it had a wide bracket on it for some reason.
Offline hrf
« Reply #9 on: 23 January 2007, 12:20 »
Did you ever find that diameter reducer? My steel exhaust is doing what steel does best ... make rusty holes, it's getting louder by the day.
HRF!!
