Author Topic: Oil Pressure Problems - Any ideas  (Read 2331 times)
Offline GaGti
Re: Oil Pressure Problems - Any ideas
« Reply #10 on: 03 January 2007, 01:36 »
ty for your replys lads...how hard is it to remove the sump? and ill check the wires as you recommended :)
« Reply #11 on: 03 January 2007, 08:03 »
sump is fiddly but not too hard.  Its held on with bolts, but the 3 between the engine & gearbox are tricky to get to.  There is a thin metal dust plate that you need to remove, then use a wiggle extension to get to them :)
