Author Topic: Just got a MK3 GTI 8 Valve - what do I need?  (Read 2329 times)
Offline boneybradley
  • Back in a Mk3...
Re: Just got a MK3 GTI 8 Valve - what do I need?
« Reply #10 on: 11 December 2006, 19:18 »
Welcome.....and don't diss the 16valver's as you will cause a riot with a few on here!!!! ;D
And any really good trye place will help set your camber and post some piccie's on the mk3 section and explain what your plan's are...see what feedback you get!
Offline silkyballs
  • more tea vicker??
« Reply #11 on: 11 December 2006, 19:23 »
theres nothing to diss on the 16v apart from theyre slow and theyre a mk3!lol only joking dude yours looks real clean.the camber will not sty where it is if it has uprated legs on it as the bolt holes are oval to allow for adjustment you need the camber bolts as they act like cams keeping the wheel alinement true if you dont use them and you have uprated legs on it then every time you go over a big bump you run the risk of it all moving again.i thing theyre about £12 from dub thats how much mine were! ;D
http://[img]
