Author Topic: TOP SPEEDS  (Read 14123 times)
Offline mk3tdi
Re:TOP SPEEDS
« Reply #50 on: 10 March 2004, 22:00 »
to add to the confusion... if big wheels are fitted increasing the rollilng radius this would probably compensate for the <10% over-reading built into speedos, right?
if the tachometer is accurate (why would it read over?) and you know the ratios would this not give the most accurate measurement of speed???
i do have slightly larger wheels than standard and on my TDI my tacho reads a fraction under 1000rpm per 30mph in top, when i checked the manual it all added up - quotes 29.6mph/1000rpm....
oh and I got 124 on the clock but mine has K&N and modified Injectors so is clearly not 90bhp any longer....
Offline hakan
Re:TOP SPEEDS
« Reply #51 on: 16 March 2004, 21:00 »
