Author Topic: sick of my rough idle  (Read 8273 times)
Offline Miacant
Re:sick of my rough idle
« Reply #10 on: 25 February 2004, 12:58 »
Gambit, 8v it is.
Getting fed up with it now.
Offline Gambit
« Reply #11 on: 25 February 2004, 14:08 »
it has to be an ISV problem as this is what keeps the revs at a constant 1k rpm.
when the car is cold the ISV will open the throttle that little bit extra to keep the revs that bit higher
when driving the car and coming of the throttle, say changing up and down gear do the revs plummet or do they drop slowly
if they plummet the ISV aint working, they should drop slowly
also, check and feel if the ISV is gently vibrating when the engine is running.
or easier would be to disconnect the ISV, start the engine - then feel the ISV
stop the engine, reconnect it, then restart and feel the ISV - you should feel a difference
my dodgy idle was simply a dirty terminal/switch on the ISV temp sender
« Last Edit: 25 February 2004, 14:10 by Gambit »
Offline forzanerazzurri
« Reply #12 on: 25 February 2004, 19:57 »
my isv is working properly,  i unscrewed the idle screw and cleaned it out a bit then screwed it back in and it ran a little better now my idle is fine until the engine warms up then it does it again,  maybe i should clean out my throttle body?? in behind the idle screw as i saw lots of oil on the end of the screw when i unscrewed it?
'85 MK2 GTI BIGBUMPERS NeuspeedTurbo/SportSprings,Lowered 2"on15" BBSw/NittoTyres, PortPolish, Bored, 16VThrottleBody, NeuspeedShortShift, DubspeedBigBoreIntake, SwayBar, Racing
Offline richy
  • neeeeeeeowm
« Reply #13 on: 25 February 2004, 20:04 »
I had rough Idle and misfiring (when warm) - replaced temp sensor and is smooth as a baby through a blender now.  ;)
Engine was getting too rich a fuel-air mixture when warm
« Last Edit: 25 February 2004, 20:07 by richy »
54-plate Golf 2.0 FSI GT.  Leather interior.
« Reply #14 on: 25 February 2004, 20:10 »
hmm mines not misfiring i dont think?  but how much does a temp sensor go for and where does it go? how easy is the install?
Offline richy
  • neeeeeeeowm
« Reply #15 on: 25 February 2004, 20:18 »
Got mine fixed under warranty.  Afraid I don't know much about fitting em, but think they're pretty cheap (~20 squid(?)).  As I said, was done under warranty so not sure of price.  Sorry!
Veedubgt18v
« Reply #16 on: 25 February 2004, 20:21 »
temp sender is about 12 quid i think it is the blue one on the union on the front of the block. hold up and i will post a link for you about idling.....
Veedubgt18v
« Reply #17 on: 25 February 2004, 20:24 »
try this.......
http://www.btinternet.com/~gvk_motorsport/diduphart.html
as well as cleaning the idle screw, check the gasket on the throttle body and all the vacuum hoses, get some carb cleaner and clean the throttle body and inlet manifold aswell, cant hurt! also make sure there are no air leaks from any rubber hoses and that your breather on the rocker cover is fitted correctly
« Reply #18 on: 25 February 2004, 20:28 »
thanks   a bunch for the info,  will this still work even tho my 8 v isnt Digifant ( i dont think)  hmm blue plug,  is there any way you can get a picture of this ?
Veedubgt18v
« Reply #19 on: 25 February 2004, 20:29 »
hold on i will see if i can find this picture blue posted.........
im not sure if it will work if it isnt digifant, cant hurt to try?
