Author Topic: mk4 gtiT knocking noise  (Read 6574 times)
Offline Starry
  • http://planetweed.co.uk
Re:mk4 gtiT knocking noise
« Reply #10 on: 17 January 2004, 06:50 »
hi kniterider. if you go on to the c&r web site you can see a pic of them.
All they are the brackets aech end of the anti roll bar and all thay do is slightly move it away from the drive shaft. If you whanted to make a set the best way would be to take off the offside wheel jack the car up so the wieght is of the suspension and disconect both brackets so you can move the anti roll bar up and down. then drop the car on to axel stands so all the wieght is now on the suspension as if it was on all fours. move the anti roll bar to the best position away from the d shaft and mesure the distance between the to bolt holes and thats the size you need your bracket eyes to be. the only problem i could see you having are the bushes.But im sure you can sort somthingout. Hope this has helped, if not there about ?80 delivered and take about 20 mins to fit..
Starry 8)
1.8T 200bhp/237lbft.r32 F/BUMPER/ MILLTEK TURBO BACK,WITH HI-FLOW CAT/REVO/BAILY DV30/FRONT MOUNT I/C
