Author Topic: crank or cam sensor  (Read 2926 times)
Offline SLIM-DUB
Re: crank or cam sensor
« Reply #10 on: 01 November 2006, 19:11 »
could the ecu relay cause all the running problems that im having?it did go all of a sudden and started to run badly after a few days where it worked fine  :huh:
<br www.vwwold.co.uk<br />PIMPASAT 20v se
Mint Finish!
Offline AudiA8Quattro
« Reply #11 on: 01 November 2006, 19:13 »
Yes.
I replaced those relays on a mk3 16v earlier this year.
The guy at vw even admitted the ecu relay was a problem, hence why they keep them in stock.
Offline SLIM-DUB
« Reply #12 on: 01 November 2006, 19:23 »
right well i guess i'll be on the fone in the morning then,easier to do that than change the sensor! thanks for all the help its much appreciated,all i want is my vr back!!  :cry: mind u when it is fixed the amount of new parts that have been fitted,it should run like a new car!  :wink: finger crossed!!
Mint Finish!
« Reply #13 on: 01 November 2006, 19:25 »
If that fails then i would try a fault code reader.
Offline SLIM-DUB
« Reply #14 on: 01 November 2006, 19:43 »
if all this fails it'll be at volkswagen at the weekend!lol!  :wink:
Mint Finish!
« Reply #15 on: 01 November 2006, 20:37 »
Is it still popping fuel pump fuses?
Offline SLIM-DUB
« Reply #16 on: 01 November 2006, 21:32 »
nope,sorted that,got the pump out and found that the wires were chaffed so whenever i hit a bump or turned sharp,the fuel would slosh up,hit the wire and the fuse would pop! nitemare way to find out,after replacing fuel filter,air filter,lambda's etc etc.......
Mint Finish!
« Reply #17 on: 01 November 2006, 21:34 »
I told you to check the pump  :grin:
Offline SLIM-DUB
« Reply #18 on: 01 November 2006, 21:49 »
just rub it in why dont ya!!!  :wink: :grin: now im getting the relay,just to see if its 2 out of 2 for you!  :wink:
Mint Finish!
« Reply #19 on: 04 November 2006, 00:18 »
So did you sort it?
