Author Topic: Longlife or time and distance?  (Read 4322 times)
Offline scotty4
Re: Longlife or time and distance?
« Reply #10 on: 26 October 2006, 19:04 »
oh right, i am much the same, 15-20 miles per day and not to heavy on the gas but there is a big difference between the mileage :sick:
MK5 GTI BLUE GRAPHITE 3 DOOR
Offline mrv
« Reply #11 on: 29 October 2006, 21:27 »
I'm on time distance servicing but when i bought oil from the stealer they sold me Castrol SLX longlife III. Is that the right oil for time distance servicing or for longlife servicing??
Offline womble68
« Reply #12 on: 01 November 2006, 10:28 »
No if you're on Time and Distance, literally the only difference is the use of Cheaper oil of a lower grade.  Longlife is 5W30, whereas Time & Distance is 10W40 when they accidentally tried to put my Car onto it.  As I said if you wanted to you could always change the oil more often but still use Longlife.  I understand to some people's minds this is a waste but I'd suggest the oil is just better for the engine in the first place.
Offline M Man
« Reply #13 on: 01 November 2006, 10:51 »
Had mine since April 06, do a lot of miles about 20K per year. had mine set for long life service however the service reminder has just come on at 10`000k. phoned stealer and they said don't worry it was set up for long life just come in and they will reset the computer!Now obviously i am now feeling a little un-easy! what do you guys think?
Offline scotty4
« Reply #14 on: 01 November 2006, 15:20 »
just got car back, and it feels and sounds great after service :smiley:
was interested to see tyre tread not worn down too much- both front 5mm both rear 7mm spare 8mm
