Author Topic: DSG What's Good What's Bad  (Read 7521 times)
Phil mcavity
Re: DSG What's Good What's Bad
« Reply #10 on: 26 October 2006, 16:04 »
did i read somewhere that the DSG Gearbox is fitted in the bugatti veyron, now if that box can handle 1001bhp, im pretty sure the gti's bhp is no problem. You are right about dsg's are worth more then manual ones, also volkswagen do actually say they sell MORE dsg's then manuals.
Offline Matt555
« Reply #11 on: 26 October 2006, 19:46 »
I think the Veyron has a hand made English unit doesn't it?
As to VW selling more DSG's than manuals?!?!  It's a sign of the times, people are getting fatter and more lazy LOL   :grin:
Offline wantmygti
« Reply #12 on: 26 October 2006, 20:29 »
Strangely, i read that Audi are not using the DSG box for the up coming R8....???
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #13 on: 26 October 2006, 21:41 »
The DSG 'box in the veyron can take far, far more power than the DSG 'box fitted to the golf etc  :shocked:
Its also around twice the size in every dimension but works in the exact same way and has 7 speeds  :wink:
The VW group are working on a 7 speed 'box for the Golf etc as we speak / type  :smiley:
Offline Matt555
« Reply #14 on: 26 October 2006, 21:41 »
Just a Manual?????
Lovely looking motor IMO  :cool:
Offline The Doc
« Reply #15 on: 26 October 2006, 22:00 »
RE: Veyron DSG 'box
The power generated in the engine is transferred to the flange-mounted direct manual gearbox (DSG). The torque and speed is then transmitted, through the gearing of seven forward and one reverse gear, via a universal drive to the front axle gearbox and via a second universal drive, along the right side of the engine to the rear axle gearbox. Both the DSG and both axle gearbox housings are of lightweight aluminum construction. The drive power is distributed to the front and rear axles by means of a Haldex coupling, an actively-controlled multi-disk, inter-axle lock directly connected to the front axle gearbox. The following front axle differential distributes the power to both front wheels. In the rear axle differential the power is distributed to the rear wheels via a bevel gear and a further differential. In addition, an actively-controlled, hydraulically-actuated, multi-disk differential lock is installed here. When necessary, it prevents speed differences between the rear wheels and ensures optimum directional stability when accelerating and when cornering under load. All load distribution functions are completely automatic and are undetected by the driver.
Offline waddler
« Reply #16 on: 27 October 2006, 13:34 »
OK drove the 2 back to back and no further forward.  Drove the DSG and thought I will take it.  Good to be able to change gear with fooot flat to the floor with no lift of.
Then i drove the manual and the car which just felt quicker and more lively.........
BTW put down 500 quid for a 30th anniversary model.
Offline The Doc
« Reply #17 on: 27 October 2006, 16:08 »
Is your head wrecked m8?  :laugh:
Offline waddler
« Reply #18 on: 27 October 2006, 18:13 »
Pretty much I mean how hard can it be to make up your mind.  Given i stumped the cash gonna see if i can squeeze a day in each out of the dealer to decide.  Good test of VW customer service.
Offline The Doc
« Reply #19 on: 27 October 2006, 18:34 »
Agreed!
At the end of the day if your going to part with your hard earned then its the best route!
I loved the little missfire thingy in between gear changes on the loan GTI DSG I had when my badly fitting rear shelf GTi was being "retified (F11CKED UP)" :wink: by my stealer.
After that I couldn't wait to get into my own DSG motor!
Plus a couple of free days in a fun GTi is not a bad thing  :grin:
« Last Edit: 27 October 2006, 18:39 by The Doc »
