Author Topic: Clifford Cliffnet Wizard  (Read 2929 times)
Offline Bazzer
« on: 24 October 2006, 18:37 »
I know it's not ICE but... ah well....
I've been thinking my clifford concept 300 keeps going off when a gnat farts in Zimbabwe, so I want to adjust a sensor. Trouble is, I dunno which one, or how. So I was gonna get a cliffnet wiard kit and see what I could do with it. Then I had the bright idea of getting hold of the software first, and seeing. So I did. I got the standard and the Pro version  :cool: but I can't find any sensitivity settings.... So back to square one?
Anyone handy with these things?
Bazzer
Offline monzablue16v
Re: Clifford Cliffnet Wizard
« Reply #1 on: 24 October 2006, 20:26 »
It will probably be a pot on the sensor itself only g5 clifford alarms allow it from CNW. Depends who installed the alarm and what they installed :laugh: helpful eh. shock sensor will be on steering column, proximity sensor near the middle of the car somewhere. HTH
Offline Bazzer
« Reply #2 on: 24 October 2006, 21:02 »
Ah really....? Well I can't see anything in the cabin on the steering column, would it be behind the dash? I've got an aerial thing with G4 on it I can see inside the car, but not sure what type of sensor this is - should I investigate with a screwdriver?
« Last Edit: 24 October 2006, 21:04 by Bazzer »
Bazzer
Offline ...joe
« Reply #3 on: 25 October 2006, 10:23 »
i've got a g4 500 and its a pain in the ass! the guy that installed mine hid stuff all over the shop! pretty sure the sensor on mine is a little black box with a sort of dial on it.
what does the cliffnet thing do then? because mine seems to have a bunch of problems... ie the indicators don't flash when you arm/dis-arm, remote start doesn't work anymore. i've checked as much as i can and have checked all the fuses i can see but it all seems fine. does the cliffnet thing let you set up the alarms features?
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline jv
  • Administrator
« Reply #4 on: 25 October 2006, 13:22 »
You can get the software here:
http://www.clifford.com/g5/wizard/default.asp
and as bazzer said, check out what you could potentially do with it.
I have the cable section if you want to use it sometime. You still need to have had the output to it installed at the time and I am not sure it is standard.
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
