Author Topic: Making my 1.6 Driver Roar????  (Read 2612 times)
Offline AudiA8Quattro
Re: Making my 1.6 Driver Roar????
« Reply #20 on: 18 October 2006, 20:43 »
Don't get an induction cone as they are wank. All they do is suck hot air in from the engine and slow the engine down.
For once i agree with Mr.Slick on this one.
On the carb engines the airbox sits behind the engine, so a bolt on induction kit will just suck in hot air, this probably will affect performance.
The best thing to do is put a k&n panel in it, and run a pipe to the grill to get a decent air intake.
BTW induction kit won't really affect cold starts, the warm air hose is not for cold starting, the system opens when the inlet air temp is below a certain level, so this is for when the car is running to prevent carb icing.
Offline infectascape
« Reply #21 on: 18 October 2006, 20:49 »
Thanks for your help man!
So whats the best way to set up the pierburg carb???
Offline Jonp
« Reply #22 on: 19 October 2006, 10:31 »
Personally i'd take it to your local garage.... They will do a exhaust gas test on it etc.
I once messed around with a SU carb... not worth it.
It shouldnt cost too much.
