Author Topic: Oil on driveshafts  (Read 682 times)
Offline golfmk2boy
Oil on driveshafts
« on: 16 October 2006, 14:34 »
Hi,
After taking off my driveshafts I noticed that they are very oily, obviously because they are rotating constantly when engine is engaged however the oil is quite thick, i think because it is old.
Is this a problem, should I look at changing the oil on these, and how would I do this?
Offline turbodub
Re: Oil on driveshafts
« Reply #1 on: 16 October 2006, 15:41 »
Do you mean CV Joint grease? If so then yes it is worth cleaning them up and re-packing the joints with some CV grease. Can be purchased cheaply from your local motor factors.
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
« Reply #2 on: 16 October 2006, 16:16 »
They will be covering in all sorts of cr@p from years of picking up er... cr@p  :grin:
Check the rubber boots and make sure they aren't split, other than that just leave them, grease/oil is great protection against corrosion, you're probably looking at the mess left from a previous split boot  :wink:
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #3 on: 17 October 2006, 00:17 »
CV joint grease can get on the inside of your road wheel! causing all types of sh!t to stick there, and then throwing the wheels off balance, clean them as well if they need it..
Tom
