Author Topic: Golf Gti 16v - front wheel arch (UPDATE: VAG do still make them!)  (Read 3903 times)
Offline ScottMk2Gti16v
Re: Golf Gti 16v - front wheel arch
« Reply #10 on: 11 October 2006, 20:49 »
Cheers guys, you're all a big help.
I actually emailed gpcvwaudi a week ago regarding it and haven't had a response. I've sent them another email and I'll call them i tomorrow as well.
All they have listed on their website is
WHEEL ARCH GTI 90 SPEC.....................£22.50
Hardly the most in depth part description ever! Hopefully that's the one I want though.
Watch this space.....
« Reply #11 on: 11 October 2006, 20:59 »
That ebay auction is the right arch, but the trim strip is snapped off.  You can easily pinch one off a scrappy MK2, but it will need to be stuck down somehow as there is only 1 mounting lug on it so it will rattle about.
VW Part:
191 853 717 C - left front - £20.93
191 853 718 C - right front - £20.93
I think you need the RHS one, its not discontinued from what I can see either, give http://www.gpcvwaudi.com a ring as well, they supply VAG parts at bargain prices :)
Just noticed on the ebay auction the seller has stated the part has a number: 191 853 718 D. Rubjonny - that's the same as the one you've put (apart you have a C and the ebay guy has a D at the end of it - what's the difference?)
« Reply #12 on: 11 October 2006, 22:48 »
191 853 718 D is for a G60 front arch, whoops should have noticed that :grin:
It will fit but as its bigger than a std GTI arch it will look odd :)
« Reply #13 on: 12 October 2006, 08:10 »
Cheers jonny - I'll give the one on ebay a miss then.  The search continues....
Offline tobz.
« Reply #14 on: 12 October 2006, 09:34 »
The gpc website is about 8 years out of date!!!
Your best bet is to give them a call and speak to julian. However I did overhear him telling somebody at inters a couple of years ago that the arch trims he had then were the last he was likely to have. Looks like they are becoming hard to find. Let us know if you find a stash somewhere, I want a complete set for mine at some point to replace some with slight scuffs.
You got any pics of your dad's split ?
Judderi
« Reply #15 on: 12 October 2006, 12:59 »
Ive got the little snapped off bit if thats any help.
« Reply #16 on: 25 October 2006, 14:06 »
Well it turns out that you can still get a VAG part. I ordered a RHF arch trim from my local VW dealer.
Part numbers are
I presume you can still get the rears as well.
All went okay fitting the new arch apart from the rust down near the bottom of the arch (as circled in red on the pic).
The very last rivet in that area couldn't go into it's original hole due to corrosion so we had to drill a new hole in the arch trim and to the car body and stuck the last rivet in.
« Last Edit: 25 October 2006, 14:13 by ScottMk2Gti16v »
Offline tobz.
That's cool to hear you can still get them from VAG, will have to get round to ordering a set pretty soon.
Glad you got it all sorted in the end.
