Author Topic: Traction control (esp) can someone please explain?  (Read 2792 times)
Offline helooooo
Re: Traction control (esp) can someone please explain?
« Reply #10 on: 03 October 2006, 15:51 »
Sorry to jump on your thread johntheboy.
But.....I have a Golf MK4 1.8 T GTi 99 plate which doesnt have ESP, can this be installed as an extra? is it worth it? and how much would it cost please?
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
« Reply #11 on: 03 October 2006, 16:23 »
I found the ESP on my mk5 hire car to be a complete waste of time and at times a little dangerous, all it ever did was cut out the power when i needed it the most  :angry:
Come into a bend nice & quick quick with plans of a bit of sideways action before powering out and you'll see what I mean  :undecided:
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
Offline Rhyso
« Reply #12 on: 03 October 2006, 17:17 »
cheaper and quicker to buy an ESP equipped car.  Alternatively go do some advanced driver training to improve
the button had (im guessing) switched it on as the traction control light was on on my dash....
as for the conditions it was wet and i understeered and went streight on!!! not very nice!
your control at the limit  :smiley:
hitting the button switches the system OFF hence why the light appears permanently in the dash.  it should only appear when you're giving it some beans and thinks you're in trouble so it engages and tries to sort you out............
Offline Dub_Dude_16v
  • Sunny Hertfordshire!
« Reply #13 on: 03 October 2006, 21:12 »
If the light is on constantly on your dash then it means the system is disabled (press button again to enable). If the light is off but flashed on and off when you loose traction then the system is enabled.
Hope that helps.  :smiley:
Offline A7 UFO
« Reply #14 on: 04 October 2006, 08:45 »
Fit an ATB diff!  £500 imported from the states and a couple hundred quid to fit if that.  Its with this level of technology that you now have fwd hatches running sub 5secs to 60mph.  What diff do you think the Focus RS used that Jeremy Clarkeson said was so "trick"?
Offline helooooo
« Reply #15 on: 04 October 2006, 13:49 »
In a word........eh?  :huh:
Sorry but that made no sense to me besides £500 outta pocket for what??  :grin:
I take it that installing ESP is not worth it then?
Thanks
Offline A7 UFO
« Reply #16 on: 04 October 2006, 14:28 »
Correct.  ESP is an electric program that cuts power when it senses a wheel slipping.  An ATB (auto torque biasing) differential is a mechanical system that directs power from the slipping wheel to the wheel with more grip.  Hence instead of increasing control by cutting power it increases the transfer of power thus making the car faster.  Much better.
Offline johntheboy
« Reply #17 on: 05 October 2006, 19:33 »
ok cheers people, at least i know where i stand now!! so if i end up going streight on when im trying to turn in a tight bend.... is it going to kick in then?? And i take it i turn off the traction control if i want to have 'a bit of fun'
Offline A7 UFO
« Reply #18 on: 06 October 2006, 09:35 »
I wouldn't say front wheels spinning up is fun....unless you want to wear down your tyres really quickly.  But yes, a differential would go some way towards powering through under steer.
Offline Fielder
« Reply #19 on: 06 October 2006, 10:30 »
^^ I Thaught VW Golf GTIs had that already?
hahahaha fielders a c**k. sorry but he is just a tit. What a waste of forum space for that moron.
