Author Topic: Anybody got any 1.3 knowledge!?  (Read 2450 times)
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: Anybody got any 1.3 knowledge!?
« Reply #10 on: 01 October 2006, 17:16 »
both manifold are the same chap  :huh:
thats the confusing thing..
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Veedubgt18v
« Reply #11 on: 01 October 2006, 17:17 »
was it working beforehand? if so just wack the undrilled one on and dont worry about it!
« Reply #12 on: 01 October 2006, 17:19 »
nah it didnt, this is the problem, they both seem to have the same blockage per se, about 1cm down, one ive now tried to unblock but faile,d the other one is bolted on to the engine and the third is bolted to the old engine, still  :laugh:
Quote
Veedubgt18v
« Reply #13 on: 01 October 2006, 17:23 »
if its blocked with metal tho that would suggest to me that its meant to be that way, a blanking plug if you will, i dont know to be honest, are u sure your looking at the right connector? cos wen i had a 1.3 there was a couple of redundant attachmenty type things similar to your pictures on the manifold but i cant remember exactly wat they did cos it was a few years ago lol we are talking inlet arent we?
« Reply #14 on: 01 October 2006, 19:03 »
Aye we are, and aye i'm looking at the right one.. now ehres the silly bit
I go to ym grandparents where te old engine is sat.. stick a bit of wire down the servo pipe, down, down, down, uhoh...
It was fully open all the way through, slightly oval hole and filed on top, its obviously ahd its blanking removed sometime.
The engine in atm, is form a H reg polo 1.3 (1990 one of the final ones like..)
The 3rd manifold I had, came with the weber i had to buy due to the pierberg needing the usual refurb job..
so the spare mnifold obviously came from a polo to, lo and behold me and my dad removed the rivet, and one open servo vacuum pipe..
But i'm jsut going to transfer the original manifold over I think.. thing is, if i unbolt my weber from the manifold and swap it across, even though i'm only swapping pipes and that, it's gonig to be ok tuning wise isnt it? i'm not adjsuting any idling or anything like that.. only swithcing a few bolts across?
Quote
Veedubgt18v
« Reply #15 on: 01 October 2006, 22:09 »
should be fine then dude u can always tune it afterwards at a garage wont cost much!
« Reply #16 on: 02 October 2006, 07:16 »
i had hoped against that, as it was onlt tuned up around about 2 weeks ago  :undecided:
as i say, i expected either direct bolt on to exact same manifold unblocked, or exact same design manifold, unblocked previous, would be ok, hmm..I guess i'll soon find out..
but thats wher ei got the diea, i'm not adjsuting any timing, mixture, idling, anything like that at all.. so I can't see ot being too bad!
possibly i could remove the pre heater from underneath and knock out the rivet through the hole elft there.. im starting tot hink aloud  :grin:
Quote
Offline JMallows
« Reply #17 on: 02 October 2006, 10:27 »
I'll try and take a photo for you later on ok? If you tell me what you want to see, and where it is  :grin:
A clever person solves a problem. A wise person avoids it.
« Reply #18 on: 02 October 2006, 15:08 »
looking at the car face on, top right hand side of the carb, should be a pipe come out on an angle o a small valve, if you take the pipe off, theres a thin pipe coming off the manifold, farthest one round, after 2 coolant pipes, its the third one, just want a shot of the top of it, where the opening is  :smiley:
Quote
Offline JMallows
« Reply #19 on: 02 October 2006, 23:20 »
Ok, i'll try tomorrow ok :)
