Author Topic: fan should it stay on  (Read 3656 times)
Veedubgt18v
Re:fan should it stay on
« Reply #10 on: 05 January 2004, 17:32 »
nah the thermostat is a mechanical device that opens at a preset temperature and lets water circulate thru the radiator, therefore cooling it. it is found at the extreme bottom left of the engine bay to the left of the oil filter, it is in a pipe that bolts to the block
Offline jasonpi
« Reply #11 on: 05 January 2004, 17:49 »
well i changed a thermo switch today which is basically a nut with a connector on it! and my mfa will always goto 100 degrees or just over half way..
one last thought remember to let ur engine cool down when changing these switches as the water that comes flying out is blooming hot :P
Blue MK2
« Reply #12 on: 05 January 2004, 18:50 »
ohh thanx all :)
I have a spare thermo somewhere. will have a look 2moro ;D
Veedubgt18v
« Reply #13 on: 05 January 2004, 19:19 »
ok if the weather is better i will put some pics up so you can see where i mean
Veedubgt18v
« Reply #14 on: 05 January 2004, 19:20 »
2moro that is
golfvr6
« Reply #15 on: 06 January 2004, 09:25 »
If you want to find the thermostat then follow the bottom radiator hose back.
