Author Topic: Problems with quickshift  (Read 1104 times)
Offline Ryan
  • Scotland
« on: 23 September 2006, 19:02 »
Hi all
I fitted a rally design quickshift kit to my golf today but when i put the weighted shift rod back on it would not go into 1st 3rd 5th or reverse. :huh: :huh:
Has anyone else experienced this problem and if so how did you overcome it?
cheers
WANTED:: 16v crankshaft pulley and rear windescreen washer bottle
Offline Mr Blue
Re: Problems with quickshift
« Reply #1 on: 23 September 2006, 23:27 »
u have to bend the weighted shift rod pins so that it doesnt rub against the box.
Dont bother with the weighted rod mate. makes no diffrence with the quick shift
« Reply #2 on: 25 September 2006, 11:58 »
I disagree, you need the weighted rod more with a short shifter as you loose leverage due to the shorter shift.  Fitting a weight helps give you a bit more force when you change gears.
Try flipping the weight over the other way if you get me, can help if its catching on the box or linkages!
