Author Topic: Rotating Mk2 16V Camshafts  (Read 1071 times)
Offline Xiotis
« on: 20 September 2006, 23:22 »
I have the head off and I want to rotate the camshafts, which one do i move and how do i move them?
Thanks. :smiley:
Mk2 Golf GTI 16V
Offline Gambit
Re: Rotating Mk2 16V Camshafts
« Reply #1 on: 21 September 2006, 12:40 »
what do you mean how do you rotate them?
when refitting the head, the marker dots on each cam should face each other
Offline Xiotis
« Reply #2 on: 21 September 2006, 14:02 »
Thanks for replying Gambit.
What I mean is how do I turn the camshafts in order to align them, so I can set the head to the correct position for fitting to the block at TDC. Is it just a question of butting a socket on the Cam sprocket and turning? Or is there another way?
Cheers  :smiley:
Mk2 Golf GTI 16V
Offline Gambit
« Reply #3 on: 21 September 2006, 17:31 »
aye just turn the inlet cam until you see the dots on either cam aligned to one another
one dot will be pointing @ 3'oclock & the other @ 9'oclock. once this is done then that is it TDC ready to refit
you understand what im on about??
Offline Xiotis
« Reply #4 on: 21 September 2006, 20:47 »
Sorry Gambit I still no understand...   :laugh: :grin:
I am not sure where or how to turn it :)? Where is it safe to turn it and what do I use to turn it? I know I am probably making a mountain out of a mole hill here, sorry... :embarassed:
I have only experience with a SOHC engine, where you normally have a ridge in the centre of the cam, where you can safely place an adjustable spanner around the cam and turn it.
Cheers.
Mk2 Golf GTI 16V
Offline Gambit
« Reply #5 on: 22 September 2006, 09:20 »
aye just turn it on the cam sprocket
Offline Xiotis
« Reply #6 on: 22 September 2006, 09:51 »
Thanks mate!  :cool: I knew it would be something simple...
Mk2 Golf GTI 16V
