The garage
blown dash light
Topic: blown dash light (Read 2167 times)
Blue MK2
Guest
blown dash light
04 January 2004, 17:39 »
I dissconnected the oil temp sensor and the oil pressure sensor. Now the MFA light bulb has blown for some reason
Is this easy to replace, is it inside the clocks?
I dont want to take the clocks out to have a look coz im lazy
Dragon6
Here all the time
Re:blown dash light
04 January 2004, 18:41 »
Yes Blue you have to take out clocks afraid the bulb is on the back of the clocks push and twist affair same as the two on top of the clocks,easy enough job,speedo cable can be a bit fiddly to dis/reconnect otherwise no bother..
Blue MK2
Guest
Re:blown dash light
04 January 2004, 19:16 »
cheers. I hate taking the front dash part out! Have to do it 2moro then
Gozza
Re:blown dash light
06 January 2004, 12:04 »
oh and as far as I am aware you can only get the bulbs from main dealers.................has anyone else got them from other places ??
Looking for an amazing rate on US/EU currency - click here plus wave the £9.95 fee if you load with more than £50
Childrens clothing at rock bottom prices here
Blue MK2
Guest
Re:blown dash light
06 January 2004, 12:07 »
I went into halfords and couldnt find one. Ill go VW in a few minutes. Its 7 doors away
kniterider
Guest
Re:blown dash light
06 January 2004, 12:17 »
i put 2 in me dash yesterday!! got some from car shop werent the same but got em to fit with some modifying of the new bulb holder!!! lol
modulater
Re:blown dash light
Reply #6 on:
06 January 2004, 20:03 »
You can buy the little osram style bulbs in main dealers, the ones stocked in halfords are different and wouldn't fit and in the end I had to buy mine in a motor factors.
As a guide the black based bulbs are 1.2w and the blue based versions are 2w.
The fun bit on mine is the heater control panel bulb has blown and its moulded in so you need a whole panel.
Looking into replacing them with blue LED's
The garage
blown dash light
