Author Topic: Wire on a bracket loose within the passenger side front wheel - plz help!!  (Read 1127 times)
Offline naz2u
hi guys,
i had my front wheel on full lock and noticed a wire on a bracket loose by the calipers. the bracket measureing 10cm by 1cm (flat) had a little screw on the end... hence most likely was screwed on somewhere there...??? thorugh the bracket a wire running through-ABS wire???
Can anyoe tell me what this is and how much will it cost to put it back on... God knows since wen its been like dat...!!?? I checked the drivers side wheel and couldnt find something liek that...
Naz
Offline GolfGL
Probably you wear indicator as mine only has one on the psg side. Is the wire snapped or still attatched?
If its snapped best to get new pads. If its still attatched get it bolted back on.
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline naz2u
wire still attached to bracket... pad has loads of life left... will take a pic and attach it somehow...
