Sounds good to me - I'm off to get them ordered I think....
Only thing I'm a bit concerned about is that I've read if you go lower than 30mm (ish) it may move the wishbone into a bad position? Should I be worried about that?
Just ordered everything apart from the springs:
03456 Strut Mount (x2) £15.10
08384 Bumpstop (x2) £4.62
14958 Strut Mount Kit (x1) £6.69
19381 Spring Plate (x2) £8.48
01525 Bumpstop (x2) £9.88
170130 Front Shock Absorber (x2) £100.20
105776 Rear Shock Absorber (x2) £49.70Does all that look about right
Just want to dig a little further into the Eibach lowering springs - 20mm or 40mm - will the wishbones, etc be okay regardless?
