Author Topic: HOW TO: VDO GAUGES - UPDATED!  (Read 40166 times)
Offline X4MGS
  • VAG Parts SNOB!!!
Re: VDO Gauges & oil temperature sender
« Reply #10 on: 29 March 2010, 00:17 »
No, the one with the green wire, it's the same shape as the new sender
Sorry for being thick.... But you said if it has 0.3 bar it goes on the head...
Now you are saying it goes on the oil filter...
See why I am getting confused...
For More Info Click To See;
« Reply #11 on: 29 March 2010, 11:08 »
he is saying the 2 pin pressure sensor goes in the head. the blue oil temperature sensor goes where the small white one with the green/black wire is on the oil filter, then you can fit both the white mfa and blue vdo oil temp sensors in the same hole :)
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #12 on: 29 March 2010, 11:27 »
Right It's now becoming clear...
The VDO twin sensor fits here...
and I use the T piece with the White & Blue temp senors in one of these holes in the top of the Oil filter housing - Here;
And I run a wire from the Temp gauge to the Blue topped temp unit and another wire to the 2nd spade on the VDO sensor to the pressure gauge...
Yeah....
Thanks Guys.... :smiley:
Very Helpful...
« Reply #13 on: 29 March 2010, 13:19 »
indeedy :)
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #14 on: 29 March 2010, 13:46 »
Thanks for the info Guys....
Very much appreciated..
Tomorrows job sorted!!!
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #15 on: 30 March 2010, 18:59 »
Job Done....
Here are some piccy's if anyone want to use em as a guide....
I had to exchange the Blue Audi 180 temp sender for a VW 170 one... Fortunately my dub dealer is very understanding and will do stuff like that for me.... Mind you it takes me an hour to pick up bits as they always want an update on what I doing to her next...
VDO Pressure unit fitted in the head...
T Piece With 2 VW Temp senders.
Working Gauges... Whoooooooooooooooooooh
Offline Ben Lessani
« Reply #16 on: 31 March 2010, 13:57 »
Good effort.
For anyone else searching, this might come in handy ...
http://www.golfgtiforum.co.uk/index.php?topic=49436.msg939943#msg939943
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #17 on: 31 March 2010, 16:13 »
 :cool:
Wish I had of found that before doing mine...
