Author Topic: Mk3 MFA  (Read 2059 times)
i-espedair
Mk3 MFA
« on: 31 December 2003, 17:31 »
When i start my engine i get the following displayed where the total millage is usually on the left!
n1 1oo
Somink like that anyway. Its only there for a second then the millage comes back up!
Car is due for a service, has been 9000 since the last one. I know this means something - oil change i guess - but can anyone confirm this or tell me where i can find a list of the MFA codes! Also how do i reset it?
Thanx
golfvr6
Re:Mk3 MFA
« Reply #1 on: 31 December 2003, 18:06 »
OEL   - oil change due
IN 01 - 12 month/ 10k service due
IN 02 -  24 month/ 20k service due
kniterider
Re:Mk3 MFA
« Reply #2 on: 31 December 2003, 20:16 »
dunno if mfa display/mileage the same as on mk4 but i kno whow to clear all mk4 service codes!!,
put key in ignt (not turned on yet) hold down reset button near (mileage clock) for about 6 seconds, turn on ignition then you should get '-----' or similar then turn your clock reset button either left or right to eliminate this then display back to normal!!, welll this is fo rmk4s so no promises it will work on a mk3!!!
Offline adyh
Re:Mk3 MFA
« Reply #3 on: 05 January 2004, 16:30 »
Vr6 has the codes,  the reset is found in the handbook .
