Golf mk1
Oil leak
Topic: Oil leak (Read 2879 times)
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: Oil leak
Reply #10 on:
07 September 2006, 09:11 »
Whats the problem? If it has an oil cooler then you'll need to remove this before you can get to all 3 mounting bolts
Danny
Re: Oil leak
Reply #11 on:
12 September 2006, 22:24 »
You know... Its leaking from the top of the oil cooler! Finally found the source. Is there a gasket there? How do I take the cooler off?
No DuB should die.
rubjonny
10k hero
Re: Oil leak
Reply #12 on:
13 September 2006, 08:12 »
Take the oil filter off, and you'll see a large nut on the thread, remove this and the oil cooler will come off. There is a rubber o'ring seal on it
Danny
Re: Oil leak
Reply #13 on:
25 September 2006, 20:29 »
Wow! That was so easy. No more leak! The O-ring on the oil cooler was old. Replaced it and all dry now. Thanks for you help rubjonny!!!!
No DuB should die.
rubjonny
10k hero
Re: Oil leak
Reply #14 on:
25 September 2006, 23:20 »
sweetness
Golf mk1
Oil leak
