Author Topic: vr6 noise/rattle???  (Read 2263 times)
Offline AudiA8Quattro
Re: vr6 noise/rattle???
« Reply #10 on: 03 September 2006, 17:15 »
The big bolt is the tensioner.
Unfortunately i haven't got any pics of it stripped down.
When you do remove the cover, be careful not to damage the headgasket, and yes it does come out that far!!!  :grin:
I'm not sure what you will need to take off, the coil, the tensioner, probably the inlet manifold and cam cover as well.
More than likely it is a broken guide rail, they are plastic sh!t, once stripped down it is easy to replace, i done mine when doing the head gasket.
I would also recommend replacing the tensioner bolt as well, the early type are hydraulic only, and can fail.
I have still got the bentley mk3 manual, let me know if you need any more help  :smiley:
Offline Fraiser
« Reply #11 on: 06 September 2006, 12:19 »
There is a complete how to with pics on mk2vr6.com - under the how to pages - have a look - seems a pretty straight forward job to do
