Author Topic: Poor idle on mk3 gti 8v  (Read 2854 times)
Offline ace
Re: Poor idle on mk3 gti 8v
« Reply #10 on: 06 September 2006, 18:15 »
had similar problem on my mk3 gti just after i serviced the car. the car was idling very roughly. cleaned all the breather pipes and throttle body, changed relay no.30 but nothing happened. decided 2 try my old spark plugs again after cleaning them up with wire brush. since then touch wood the car has been running back 2 how it was b4.
Offline low_v_dub
« Reply #11 on: 06 September 2006, 19:38 »
So it could be the plugs or my leads? the spark plugs are from VW, its got a set of HT leads on there that dont look like the standard VW ones, i think they been replaced... could this be the prob..?
Offline ace
« Reply #12 on: 06 September 2006, 21:12 »
before i put the old plugs back in, i changed the ht leads, but they never made a difference to my problem. both the plugs and leads i bought from gsf. i also had a diagnostic check done on it and i got 2 faults, the air intake sensor and the engine coolant sensor. i changed both of these as well but again no change. u can try the plugs first as thats the cheaper option before u try the leads.
« Reply #13 on: 07 September 2006, 09:15 »
What plugs did you get?  I find the single electrode ones often end up getting the ends bashed in so throwing out the gapping.  3 elecrode ones dont have this problem though
Offline ace
« Reply #14 on: 07 September 2006, 11:25 »
not sure how many electrodes to be honest, but they were the bosch W7LTCR plugs. strange cos they were the ones that i had put in before as well
« Reply #15 on: 07 September 2006, 11:57 »
Ok they should be 3 electrode ones, probably not to do with those then.
Have you checked the idle switch clicks when the throttle is closed, and tested it electrically with a multimeter (does the MK3 GTI have an idle switch??)
