Author Topic: mark 3 Sunroof  (Read 1824 times)
Offline Len
Re: mark 3 Sunroof
« Reply #10 on: 29 August 2006, 13:06 »
If the motor is working then I dont believe its the cause of your problem.
www.sas.org.uk
www.the-ace.org.uk
Offline Gozza
Re: mark 3 Sunroof
« Reply #11 on: 29 August 2006, 14:14 »
Right thats it I will get the bastad thing moving at the weekend, thanks for your help all I will keep you informed.
On another note, when I finally get the thing moved anyone got a good way of removing all the crap from the drainage holes ?
Thanks again all
Re: mark 3 Sunroof
« Reply #12 on: 30 August 2006, 09:14 »
a metal coathanger will do the trick, just tape up the end so it doesn't punch a hole in the tubing anywhere.  why not try at the bootoms of the drains first, perhaps thats where the blockage is ;)
AFAIK they drain into the front/rear arches :)
Edit: Also check where the drain tubes pass thru the front wings just in front of the front doors, on a MK2 they pass thru a small hole, they sometimes get pinched between the wing & bodywork if someone has had the wing off in the past.
« Last Edit: 30 August 2006, 09:16 by rubjonny »
