Author Topic: part name needed (or confirmed) - gearbox seal  (Read 818 times)
Offline bretttuk
« on: 20 August 2006, 11:03 »
Hi , i posted before but no success due to the subject name i think. Basically , my gearbox is leaking from the driveshaft seals , i was wondering if that is the correct name for the part, i am looking on VWspares, gsf but cant seem to find anything of the same name, was wondering if anyone can tell me the correct name for the part i am talking about..
also, what is the capacity of the gearbox for gearbox oil?
car is a 91 mk2 16v golf
thanks
brett
Offline Lewy
Re: part name needed (or confirmed) - gearbox seal
« Reply #1 on: 20 August 2006, 11:18 »
You may find that the seals are a VW part only, i.e, not available as a pattern part. But don't dispare, VW aren't that expensive. And as for the oil it's about 2-3 litres, and you'll know when it's enough as it'll be dribbling down your arm!
Offline AudiA8Quattro
« Reply #2 on: 20 August 2006, 12:13 »
Drive flange oil seal, and the gearbox take 2.1 litres of oil, however 2 litres will be enough as there will always be a bit left in the box.
Offline bretttuk
« Reply #3 on: 20 August 2006, 13:22 »
Thanks for the info, is this available from any online place like gsf, vwspares etc.. ? if so, could someone point me to the right part URL .. so i dont make any mistakes , i can then order it..
thanks
Brett
« Reply #4 on: 20 August 2006, 13:32 »
Best to ring GSF or Euro Car Parts and ask them.
