Author Topic: m.o.t....FAIL!  (Read 920 times)
Offline redders
  • 88 8V GTI, 3dr helios blue
m.o.t....FAIL!
« on: 17 August 2006, 18:41 »
HI  all mega failure on the old girl......
corroded brake pipes, leaky caliper (rear), park brake efficency down too 13% :sad:
exhaust emissions  excessive. :sick:
oh and something very odd with the lights too.....lights on indicators on left hand side and they flash alternatley :shocked:
any ideas on the lights would be gratefully recieved..lol
cheers redders
Offline baz_the_man62
Re: m.o.t....FAIL!
« Reply #1 on: 17 August 2006, 21:49 »
check all your fuses, i had a fuse go and my dash light dimmer was controlling my rear number plate lights, changed the fuse and it was all good again. failing that it might b an earth/bulb/relay.
Offline redders
Re: m.o.t....FAIL!
« Reply #2 on: 18 August 2006, 14:15 »
just been down to my local vw workshop, they reckon its a bad earth.......corrossion maybe?
Re: m.o.t....FAIL!
« Reply #3 on: 18 August 2006, 20:34 »
take the passenger side boot trim off, you'll see the earthing point for the rear lights.  Clean this up and check all the connections on the rear lights for corrosion :)
Offline redders
Re: m.o.t....FAIL!
« Reply #4 on: 19 August 2006, 13:08 »
cheers rubjonny, spot on as usual..........when i  put a better condition boot lid on id disconnected  the wiring  and must have  only re-connected two of the three earth wires.
cheers
redders
