Author Topic: Coolant Leak  (Read 6931 times)
kniterider
Re:Coolant Leak
« Reply #10 on: 29 December 2003, 20:46 »
sounds like head gasket to me!!!!!!, im not 100% but thats what i reckon!!! ::) ::) ::), not a mega hard job on an 8v!!!, dunno if haynes manual up for it, try bentley manual or download it!!!, thats what vr6 and richandhazel use ive got a ahynes but then im thick!!! ::) ::) ::)he he he
golfvr6
Re:Coolant Leak
« Reply #11 on: 30 December 2003, 00:08 »
Ive changed the expansion tank and there is still no difference, its really peeing me off >:(! Coolant is still leaking from the overflow of the expansion tank and it is still hissing.
Anybody got any ideas?? ???
Much Appreciated Cheers ::)
It is your headgasket leaking, thats exactly what happened to my car. You can find out for sure by getting a garage to test the coolant system for exhaust gases.
DON'T leave it, if you do the head will corrode at the leaking point, i caught mine just in time.
Offline Rob
Re:Coolant Leak
« Reply #12 on: 30 December 2003, 10:01 »
sounds like you have the same pain in ass car i had.
changed expansion tank and cap still did it.
Head gaskett. i also sent head away to be skimmed,just to be safe
problem solved for me.
Blue MK2
Re:Coolant Leak
« Reply #13 on: 30 December 2003, 10:12 »
is there a certain amount of times the head can be skimmed? How do i check if its been skimmed before?
golfvr6
Re:Coolant Leak
« Reply #14 on: 30 December 2003, 10:42 »
measure the height of the cylinder head.
there is a limit on how many times u can skim it, cannot go below a minimum height.
Offline m4nesh
Re:Coolant Leak
« Reply #15 on: 30 December 2003, 14:41 »
Got some mechanic to test the coolant for cylinder gases, he stuck a bottle of blue liquid on the expansion tank and to my dismay it turned yellow.  bastard bastard bastard! >:( >:( >:( >:(
Guizer will come down to my home to fix it, including skimming the head and genuine parts for no more than ?200 :'(  Said it will take two days as the head will need to be dropped of at the engineers?
Is this an ok price?
Anything I need to be vary off because I found this VW specialist from the yellow pages.
P.s. will he have to renew the oil????? ???
Blue MK2
Re:Coolant Leak
« Reply #16 on: 30 December 2003, 15:17 »
200 sounds cheap, i was quoted ?300 for mine :'(
Offline m4nesh
Re:Coolant Leak
« Reply #17 on: 30 December 2003, 16:35 »
I was quoted ?383.23 parts and labour by Volkswares in Leicester,
thats taking the piss, to many $$$$$,
Offline Rob
Re:Coolant Leak
« Reply #18 on: 30 December 2003, 18:06 »
mine cost around ?200 to be done
I had a bit of spare cash around at the time so i went the distance.
water pump
heater matrix
and a couple hoses
Offline Helios_Blue_Valver
Re:Coolant Leak
« Reply #19 on: 30 December 2003, 19:58 »
sounds like a fair price. as for the oil, when in doubt change it! Oil is one thing I get real picky about in my cars.
