Author Topic: Hello! My 8v K-jet Golf!  (Read 1753 times)
Offline Malz0r
  • Haters gunna hate.
« on: 11 August 2006, 09:34 »
Hello and nice to be here! Just signed up after using this site for a long time for problem solving! I must say a first you guys help more people than you know!
Anyway need a few things cleared up for me if anyone could help.
Im 19 on my 2nd mk2 Golf had my 8v GTi for about 2 months (after my old 1.6 Driver died of rust) and there's a few minor problems! When i first got it, it missed like hell, stalled at juctions and stutterd up hills. That was fixed with new sparks leads and dizzy so all runs fine now.
First problem - when i take the car over 4 revs and put my foot down on the clutch it feels like the cable is catching or something? now iv had a new cable put it and it still does it, dont seem to do any harm but would still want to fix it as it worry's me abit lol!
Next problem - when i pull away there is an odd noise, like when a drive shaft goes does it once or twice only when pulling away stops after a sec or two or sometimes not at all? Iv been told it may just be the age of it (its 19 aswell) so it could be nothing but still lol
Final problem - the small rubber thing on top of the rocker cover has gone to pot, i brought a new one but it was the wrong chape i presume the Digi engine one, i need one for the K-Jet cover? where and how much if any one does?
Well thanks for your help sorry if anything is abit hard to understand but im no expert by a long way ,thank again!
Better put all the info of my car.
1987 E Reg (K-Jet) 8 Valve
Offline Malz0r
Re: Hello! My 8v K-jet Golf!
« Reply #1 on: 15 August 2006, 10:48 »
UPDATE :
Driving back home two days agao, all was fine untill the revs started dropping really slowly, the gas did nothing, pumped it like hell did nothing, then dumped the clutch car cut out and has never started since.
It sounds like it trying to start up but just cant? i have all ignition lights on just wont get there :( please help.
Offline gillo_grumlin
« Reply #2 on: 16 August 2006, 10:00 »
The rubber bung at the top of rocker cover is a breather bung only a couple of quid from dealer or gsf (or ebay).
Sound like the fuel pump relay is suspect check and replace if required.
Judderi
« Reply #3 on: 16 August 2006, 11:22 »
Yeah id suspect the fuel pump also. Turn your ignition on and listen for the hum of the pump. You should hear it for about 2 seconds then it will cut out. If you dont hear it then 1st change the fuel pump relay.
Another thing to check would be the intake hose from the airbox. This must be sealed and have no splits or gaps in it anywhere. The k-jet system needs to be airtight in order to work.
Offline Malz0r
« Reply #4 on: 17 August 2006, 08:48 »
Hi, thanks for the response. I called my guy he said the "igition module" (i think he siad that) has gone, should be back today, and as for the rubber thing on the rocker cover i got one off ebay but it was the wrong size, or at least didnt look right? re they the same on the digi engine as the k-jet?
Judderi
« Reply #5 on: 17 August 2006, 08:56 »
Do they have an ignigion module? ask him which part that is exactly or get him to point to it.
Offline Malz0r
« Reply #6 on: 17 August 2006, 08:56 »
I have no idea? the guy that is doing my car own's the whole place so he know's whats he's doing. But put it this way, he orderd one in for "my" year of car so im gussing it does have one, well i hope so anyway lol i havnt been up to see the car since i got toad up as it's like 6-8 miles away from where i am lol
Oh and i have replaced the fual pump about a month ago so that should be fine, also had the air intake's all cleaned out at the same time, the rubber tning has never coverd the hole up right sinse i had it, never seemed to have affected it yet?
Judderi
« Reply #7 on: 17 August 2006, 09:08 »
id want to see the old and new parts personally. i just dont trust mechanics anymore sadly.
Offline Malz0r
« Reply #8 on: 17 August 2006, 09:10 »
Well thats fair enough, but th guy doing my is going out with my mum's sister, and i get discount on top so i trust him in what he does, i can always take a picture of it for you just for future referance, i should be picking it up later today?
Offline Xiotis
« Reply #9 on: 17 August 2006, 10:06 »
Hi guys,
I am new here too and I'm  trying to get to grips with what's what.
Sorry for crashing into your post like this but I have a question, I was under the impression that all 8V Mk2 GTI Golfs used the Digifant system and the 16Valvers used the Bosck K jetronic?
Please set me right here. I am still learning.
Thanks.
Mk2 Golf GTI 16V
