Author Topic: mk3 diy shelf  (Read 2160 times)
Offline kr1s77
mk3 diy shelf
« on: 05 August 2006, 21:23 »
hi I'm making a diy shelf for my Mk3 golf, just wondered if you had any ideas on what to use for it the open up the the hatch like the original shelf does?
Thanks
ASV 1.9 TDI 110
Offline Len
Re: mk3 diy shelf
« Reply #1 on: 10 August 2006, 13:22 »
I used a bit of wire cable. Bit of black single core from 13amp household cable.
Put a screw with washer into the MDF board (edge) looped the wire round that and tightened the screw.
Top bit I looped it over the existing pegs and wound it around itself and gaffer taped it.
Dont look good but works.
Gotta change it sometime and was thinking of some small chains. Ya can get small stuff from B&Q.
www.sas.org.uk
www.the-ace.org.uk
Offline Dom Mk3
  • Insert wit here
Re: mk3 diy shelf
« Reply #2 on: 10 August 2006, 13:35 »
It'll rattle when closed. How about the standard stuff - it'll still be the right length!
Offline Len
Re: mk3 diy shelf
« Reply #3 on: 10 August 2006, 14:49 »
Was thinking more of the plastic coated stuff.
The standard stuff aint man enough! Did try that first! Just kept slipping off.
www.sas.org.uk
www.the-ace.org.uk
Offline kr1s77
Re: mk3 diy shelf
« Reply #4 on: 16 August 2006, 19:31 »
ASV 1.9 TDI 110
