Author Topic: Boot Release  (Read 7055 times)
Offline jasonpi
Re:Boot Release
« Reply #10 on: 05 January 2004, 00:08 »
dont tell me guys another m4 fault...becoming common arent they. must admit do miss my m4 but they should  fix the problems with it first b4 bringing out a new one. call me a perfectionist but its what i would do
kniterider
Re:Boot Release
« Reply #11 on: 05 January 2004, 00:38 »
will try the 'windows down' method tomorrow' if it works great if it dont if means as said each vw is set up (by vw) as per orig customers requirements!!!! will see if works with mine but im sure ive tried before but it wont have it!!! (ive now got me rosstech software) just waint for a decent usb-serial covertor as most cause probs  with vagcom software unless u have serial port!!!!!,  :'(
Offline number_six
Re:Boot Release
« Reply #12 on: 05 January 2004, 04:22 »
You can change the boot lock position manually with the key so that the boot will either unlock/lock along with the drivers and passengers doors or have the boot lock in a position so that you have it disabled from central locking and have to manually open the boot with the key everytime.
Play around with inserting the key into the boot and turn one way or the other and close the boot, then play around with the central locking to see if it opens/locks along with the doors.
I had the same problem and kept getting p!55ed off with having to keep using my key each time to get into the boot.
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re:Boot Release
« Reply #13 on: 07 January 2004, 16:29 »
'Rider, have you considered going for the alientech module thats fires the windows up or down on the standard fob?
Its an affordable mod at ?50, and is incredibly useful (as well as quite flash!)
It does:
Roll windows up
Roll windows down
Vent 1"
Vent 2"
Vent3"
it also allows you to put the windows up (or down) with the key in the lock, but you don't have to stand there holding it. Just twist and go!
It took an hour to fit, and I wouldn't be without it!
The greatest leveller of them all - the Carousel
Offline antgti
  • 130PD Gti with Van aaken chip to 165 has now gone,
Re:Boot Release
« Reply #14 on: 09 January 2004, 03:46 »
COR PUTTING OUT FIRES ALL NIGHT HERE, THE REASON YOUR BOOT IS NOT OPENING OFF OF THE KEY IS BECAUSE YOU HAVE TO MAKE SURE THE LOCK ON THE BOOT IS IN TH RIGHT POSITION. I THINK IT SHOULD BE HORIZONTAL IF YOU WANT TO BE ABLE TO OPEN IT USING THE REMOTE. IF IT IS IN LOCKED POSITION THEN IT WILL NOT OPEN WITH OUT THE KEY, GIVE IT A GO.
IF YOU HAVE NO JOY THEN GIVE ME A CALL AND I'LL POP ROUND AND SHOW YOU HOW IT'S DONE         ( WORTH A TRY ON MY PART THERE)
Me old diesel was quick/........
16.004 sec Qtr mile @ 85mph 23/5/04 Santa Pod
Now running around in soon to be REVO'd Seat ibiza 1.8T 20v FR and missing the fuel economy..............
