Author Topic: Soundpack plus!!! What a load of.......  (Read 7416 times)
Offline The Doc
  • E63s Estate - Vito Sport
Re: Soundpack plus!!! What a load of.......
« Reply #20 on: 24 August 2006, 13:45 »
Sub amps have a built in crossover - you can lower the bass in your headunit to stop the door cards vibrating without even touching them!
Matt, try making the bad noise in your car, then turn the bass on the set to middle of the road (or lower) and see how loud it can go before vibration / distortion stops you.
Normally this is quiet loud so you can use the sub to give you your missing bass.
I'd go for a self powered 6.5" or btter still the 8"Bazooka tube - they've been around for donkeys and have the amps / crossovers built in.
The sound from this tube will compliment the VW unit very well and they only cost around £150 incl postage from the states.
Install sound cost around £50-60!
IMHO
Good Luck
Offline Matt555
« Reply #21 on: 24 August 2006, 15:17 »
Thanks for that Doc, living without bass would be so sad but it may make things a little less annoying for a few weeks  :sad:
So the Bazooka sounds like a decent option, i'll get checking the net......... :smiley:
