Author Topic: mk1 G60 - pedal box and clutch - help  (Read 1245 times)
Offline spc
« on: 21 July 2006, 15:35 »
I have 280mm discs on front and need to add a standard Mk2 16v servo and master cylinder.
Do I need to also change the pedal box to standard and if so will it support a Hydraulic clutch?  The car is already fitted with a hydraulic clutch.
Judderi
Re: mk1 G60 - pedal box and clutch - help
« Reply #1 on: 21 July 2006, 15:41 »
Bit of a confusing question. What pedal box do you currently have?
Offline spc
« Reply #2 on: 21 July 2006, 16:14 »
sorry but not very mechanically minded, but learning fast!
I have a race style bias pedal box, with rear disc conversion, using a TSR kit.  The Bias can be adjusted from within the engine bay, have 3 drums, one for rear one for front and one for clutch (if that makes sense)
Judderi
« Reply #3 on: 24 July 2006, 08:34 »
Why are you needing to convert to a mk2 servo and cylinder then? I suppose as long as you have room and can line the linkage up you should be alright.
