Golf mk3
hardmonkeys
16v Running Problems i.e No power at all!!!
Topic: 16v Running Problems i.e No power at all!!! (Read 4274 times)
mk1
2ltr16v turbo (now with programmable EFI)
Re:16v Running Problems i.e No power at all!!!
Reply #10 on:
25 February 2004, 18:50 »
There may be a sensor on the front of the engine that picks up a signal from the crankshaft. Dont think that will cause it to run rich tho.
Steve.
http://www.geocities.com/mk1turbo16v/golf_turbo.html
golfvr6
Guest
Reply #11 on:
25 February 2004, 19:01 »
I think the crank sender does engine speed, the cam sender does ignition timing.
mk1
Reply #12 on:
25 February 2004, 19:17 »
Not sure what fuel injection system he has (digifant?), one with twin coils and no distributer?.
Judderi
Guest
Reply #13 on:
01 March 2004, 12:47 »
It has a distributor and single transformer. Ive also now had the ecu tested and it has 2 faults. idle controll fault. Overfueling 15-20%. Getting somewhere i think, just need a new ecu now. Not Cheep!
Judderi
Guest
Reply #14 on:
15 March 2004, 10:47 »
got the ecu and its still not running! Raaaaaaaaaaaaaaaaaaaaaa
Judderi
Guest
Reply #15 on:
29 April 2004, 09:26 »
SOLVED! The timing was out 6 teeth and the origional ecu had an idle fault. Why didnt the 1st mechanic realise that the timing was out. Its not brain surgery is it?
Golf mk3
hardmonkeys
