Author Topic: Engine transplant  (Read 1860 times)
Offline db Sam
Engine transplant
« on: 20 December 2003, 22:35 »
will a 2.0 16v code 9a engine from a corrado fit in a mk1 cabby and is there much work involved.
cheers
Offline mk1
Re:Engine transplant
« Reply #1 on: 20 December 2003, 23:04 »
Engine will drop straight in ;D, use the clutch pressure plate for a mk2 16v and a 8v centre plate. That will make it work with your g/box (or use a mk2 16v box e.t.c.) There is a bit of messing around with hoses and injection pipes, the ign system is different(use mk2 16v parts or fit the whole corrado system) exhaust manifold is another prob but there are 4 branch manifolds for the mk1 16v conversion around. Will make a nice conversion (I have done it ;)). Good luck, and let us know how you get on.
Steve.
Offline db Sam
« Reply #2 on: 21 December 2003, 21:50 »
cheers mate. i'll keep you posted.
if i come across any problems i'll be in touch if you don't mind.
