Author Topic: 3dr Front Seat Problems  (Read 3288 times)
Offline Shins
« on: 19 July 2006, 16:48 »
Anyone had problems with failure of the sliding mechanisms? I've had mine [passenger side] 'fixed' 3 times now and am getting fed up. Only gets used twice a day so its not a wear issue.
Seat will still slide with the seat base controller but not the handle on the seat shoulder.
Anyone else?
Offline The Doc
  • E63s Estate - Vito Sport
Re: 3dr Front Seat Problems
« Reply #1 on: 19 July 2006, 22:15 »
Nope I have never had this problem  :sad:
Offline grfc
« Reply #2 on: 20 July 2006, 07:44 »
As the owner of a new 3dr I am surprised that the seats do not slide back to the original position - not a big deal due to my lack of use of rear seat - but the potential to be a real pain.
Offline adw555
« Reply #3 on: 20 July 2006, 08:34 »
ooh..sounds like you have a seat problem...mine slide back to the same position..they definitely should do :-)
Offline M Man
« Reply #4 on: 20 July 2006, 22:22 »
MINE FINE!
Offline The Doc
« Reply #5 on: 21 July 2006, 00:13 »
The seats DO go back to their original position.
Next time you pull the seat forward push it back using THE BASE ONLY - DON'T touch the backrest or handle and let us know how you get on.
As soon as you move the handle or backrest it locks the bottom of the seat in place!
Offline grfc
« Reply #6 on: 21 July 2006, 07:47 »
Will try this - without touching the bachrest - easier said than done, when the natural action is to tip the backrest forward to let someone in the rear. Thanks
Offline The Doc
« Reply #7 on: 21 July 2006, 15:56 »
The reason I say DONT TOUCH it is to see if it works
Once you know it does (or doesn't) you can then try doing it using the backrest and devlop a technique that works for you  :wink:
Don't get me wrong - you shouldn't have to develop a technique but hey ho...
Offline The Doc
« Reply #8 on: 24 July 2006, 00:37 »
???   :huh:
