Author Topic: mk2 8v inlet manifold vacuum connections  (Read 1599 times)
Offline pbaronmk1cab
« on: 12 July 2006, 22:01 »
hi
can someone pls confirm where the 2 vacuum hose connections (right near the idle screw) on my mk2 8v (1984) connect to ??
Also the thermo switch has a tpiece can someone confirm where the vacucm connection goes from there too
Paul
Re: mk2 8v inlet manifold vacuum connections
« Reply #1 on: 13 July 2006, 20:08 »
bump
« Reply #3 on: 14 July 2006, 20:10 »
got the haynes mate, so looked at that pic.
Not showing properly where they all connect to though.  Cheers anyway mate
« Reply #4 on: 15 July 2006, 09:08 »
well looking at that, one of them goes to the diafragm pressure valve, and the other is blanked off.  Then you have another vacuum line from a T piece at the front goiung to the distributor, and another line from the brake servo hose to the dash clocks.
Which one in the diagram is the thermo switch?
