Author Topic: Overheating???  (Read 1828 times)
Offline HuwMk2
Overheating???
« on: 10 July 2006, 10:16 »
Hi. My mk2 overheats very quickly while idle in traffic. The temperature gauge soars right up. I have combated this by turning the blowers on full whack and full heat. What is the problem? Is it the fan?
Judderi
Re: Overheating???
« Reply #1 on: 10 July 2006, 10:22 »
1st thing to check would be the fan. If it does not come on then there is a fault. To check if the fan is working then unplug the sensor plug in the bottom corner of the rad and bridge the pins. This should turn the fan on so watch your fingers! If it does then the sensor is shagged and needs replacing. If not then either the fan motor has blown or the wiring is fault. Replace both or do the cheapest 1st.
Offline Gozza
Re: Overheating???
« Reply #2 on: 10 July 2006, 13:01 »
This happended to a Fiesta XR2I I owned once (I know, I know) turned out to be the relay was shafted and not telling the fan to come on. Replaced it and was sorted.
Would have to agree with the replace the cheapest bits first, although if you let the car get to operating temp with the bonnet open and the fan does not come on you can limit it to the wiring/relay/thermostat after you have bridges the pins again as mentioned by the Yoda of this forum  :grin:
All the best  :wink:
Judderi
Re: Overheating???
« Reply #3 on: 10 July 2006, 13:09 »
Repeat what i have said have you not. Hmmmm
Offline frog
Re: Overheating???
« Reply #4 on: 10 July 2006, 15:47 »
Have you checked your coolant level? Also get the mixture checked,as an incorrect mixture will effect the boiling point
Offline Gozza
Re: Overheating???
« Reply #5 on: 10 July 2006, 16:25 »
Yip, shhhhh I am trying to make it look like I know what I am talking about  :evil:
Offline keefusg60
Re: Overheating???
« Reply #6 on: 11 July 2006, 14:22 »
Happened to me on my MK2 last year. Replaced the thermostat and that solved it. Had replaced the fan and fan switch first, but a thermostat + coolant is only cheap, so well worth doing first.
Judderi
Re: Overheating???
« Reply #7 on: 11 July 2006, 14:43 »
Where is the thermostat?
Veedubgt18v
Re: Overheating???
« Reply #8 on: 11 July 2006, 15:34 »
in the water pump housing behind an elbow bit of pipe
Judderi
Re: Overheating???
« Reply #9 on: 11 July 2006, 15:40 »
Does it have an electrical connector attached? Got any pics?
