Author Topic: big bumper fogs  (Read 2233 times)
Judderi
Re: big bumper fogs
« Reply #10 on: 10 July 2006, 09:17 »
Just to confirm. Is there only 1 plug and the passenger side? Isnt there a plug on the drivers side too?
Offline takethefifth
Re: big bumper fogs
« Reply #11 on: 10 July 2006, 22:13 »
There is only 1 plug and it's on the passenger side.   :smiley:
« Last Edit: 10 July 2006, 22:15 by tt5th »
Offline gribsy2006
Re: big bumper fogs
« Reply #12 on: 11 July 2006, 00:39 »
ok cool mate your a star
i wouldnt mind if you could let me know more about this soldering.
so if im right you have to solder the cable to the fog light, but how does it connect to the plug under the expansion tank
cheers mate
Re: big bumper fogs
« Reply #13 on: 11 July 2006, 01:29 »
You would have to solder the two wires for each side to whatever type of connectors the fog bulbs need.
For the expansion tank socket you would need to chop it off and strip the wires, for this one i would use bullet connectors that you crimp on. Cheap from halfords again...
You would put a single wire, that you stripped from the socket, into one end of the bullet connector and the two foglamp wires (ie. both positive wires) into the other end and then crimp them. Then repeat for the other wire.
If you were to solder these wires it would be the 'Y' connection (ie.wrap two positives from fogs onto the one positive from socket and solder). Then wrap with electricians tape! I don't recommend this way but i have done worse in my time!  :smiley:
Judderi
Re: big bumper fogs
« Reply #14 on: 11 July 2006, 10:27 »
Does anyone have a picture of the plug under the header tank?
Re: big bumper fogs
« Reply #15 on: 11 July 2006, 12:34 »
Well seems as its you....  :wink:  (and that i am on hols at the mo with not a lot to do!  :laugh:)
Thats it there!                         Right there...     ^
Judderi
Re: big bumper fogs
« Reply #16 on: 11 July 2006, 14:52 »
Cheers dude. Will have to see if i can find it on mine. Hmmm where do i start?
Re: big bumper fogs
« Reply #17 on: 11 July 2006, 17:37 »
 :laugh: Hahaha!  Good luck!!  :laugh: :laugh:
Judderi
Re: big bumper fogs
« Reply #18 on: 12 July 2006, 09:25 »
Luck has nothing to do with it, its a miracle i need! Come to think about it, where do any of these wires go?
Nooooooooooooooooooooooooooooooooo what have i started!
