Author Topic: HOW TO correctly setup 16v idle in maintainence section  (Read 5666 times)
Offline tobz.
A while ago Gambit posted a link to a wonderful guide to setup a mk2 16v idle in the maintainence section.
Unfortunately the link doesn't seem to be working anymore (at least for me), I've also tried linking to it through the clubgti site.
Does anybody have the contents of the link saved as a text document that they could cut and paste into this thread???
I have a document saved but I'm not sure if it was that one or not.
Toby
You got any pics of your dad's split ?
Re: HOW TO correctly setup 16v idle in maintainence section
« Reply #1 on: 06 July 2006, 11:11 »
I have most of it, but one picture is missing.  Let me sort it out into a decent format...
« Reply #2 on: 06 July 2006, 11:31 »
This problem gets asked about 'quite a bit' on the forums - It applies to the mk2 Golf/Jetta 16v with KR engine.
"My mk2 16v cuts out at junctions and idles terribly, I'm at my wit's end"
Ok, there are somethings you can check yourself at home.
If the ISV is working ,turn ignition on pos2 valve should *buzz*,
Make sure it isn't cogged up with oil deposits-either replace it or flush out with carb cleaner.. remove the brass air bleed screw and clean it also. If all that fails .........
Try cleaning out the inlet tracts of oil and the airflow flap. If the engine isn't hunting when cold or hot, the CO is correct. 16Vs run best at 2.0 % CO.
To achieve 2.0%, disconnect the famous "red lead" spade connector behind the coil (see fig:1 below) (after the engine is at temp), pull off the breather hose and block the airbox hole. Start the engine and the revs should plummet, if they don't, the idle valve is shagged and you're idling off the bypass screw alone. Now, with the engine running, turn the idle screw (fig: 3) up until you get 950rpm +-50.
If the idle wanders or is lumpy (engine visibly rocking), insert your LONG 3mm allen key into the CO screw (fig :2) and turn it anti clock to weaken. Just prior to the engine cutting out, turn the key clockwise in 1/8th turn increments until the idle smooths out. Eventually, the engine should settle to a nice, steady idle. This will be 2.0% or very close to.
Switch off and reconnect everything.
Take it out for a run and when you dip the clutch, the tacho needle should gently fall to 1000rpm, not plummet. If after all that it's still missing and rough, investigate air leaks around the inlet manifold and the various vacumn hoses.
If you ever need to find the controller for the ISV it's the black box with 'VDO' marked on it that's clipped to the back of the ashtray or (if someones been fiddling), shoved behind the dash in a random fashion!
If you're really unlucky and the above instructions don't sort out your particular idling issue,check that the three senders on the end of the head, under the distributor are working, 2 of these control the ISV and the other is the temperature gauge sender - the senders are all the same so as long as your temperature gauge works, you can swap the wires to make sure all 3 senders actually make the temp gauge register, obviously if one doesn't work, there's your faulty sensor.
WARNING -The sensors are about £20 from VAG so be careful whilst tightening them, they are tapered thread which means in simple terms that you don't wind them in all the way!
Thanks to Kevin Hayward for the original version of this posted on the Club GTI mailing list, many moons ago and GVK who's website I pinched this particular version of the info from :)
Offline tobz.
« Reply #3 on: 06 July 2006, 11:34 »
Jonny you're a star. it turns out that was the document I have saved but I think it will be beneficial to others to have it readily available to view on the forum.
Maybe some helpful mod could paste jonny's post into the relevant thread on the maintainence board????
Toby
« Reply #4 on: 06 July 2006, 11:36 »
have you got the 2 photos that I'm missing (the black & white ones)  It would be better if I could include them as a proper photo is always more helpful than a haynes diagram :)
Offline tobz.
« Reply #5 on: 06 July 2006, 11:38 »
Blimey chris you've done it already!!! Nice one
Yes I got them jonny, you want me to email them or post them in this thread and you can right click & save em???
Offline tobz.
« Reply #6 on: 06 July 2006, 11:47 »
Here they are jonny:
« Reply #7 on: 06 July 2006, 13:46 »
Got em thanks, i shall post them up to the m.n ftp now :)
Judderi
« Reply #8 on: 06 July 2006, 15:01 »
p.s the origional post has also been updated now.
