Author Topic: right off outside to do headlamp loom on mk2!!  (Read 3673 times)
Offline muppetsport
Re:right off outside to do headlamp loom on mk2!!
« Reply #10 on: 19 December 2003, 04:31 »
whats this loom upgrade all about then? my headlights are dim as hell with new bulbs in.
from the sacred dojo of muppetsport the grand master shall show us the way.
3rd dann black belt in car modifying. wax on wax off, engine out, engine in.
kniterider
« Reply #11 on: 19 December 2003, 16:02 »
right basically you cut the wire to the dip beam on the plug send that to a relay (+side of the coil) then to earth, then link the plug through the normally open side of the relay contact then to the 12v+ on the battery, then you get full 12v to the lamp rather than the 9ish volts that you get through the factory loom, you need to do this to both sides so to relays are needed and relevant wiring easy peasy!!! just make sure you get some decent relays!!! i have now!! ;D ;D (basically its how youd wire up spot lights etc but running orig lamp off old lamp feed) :D
