Author Topic: MFA wierd any ideas  (Read 1895 times)
Offline gribsy2006
MFA wierd any ideas
« on: 02 July 2006, 19:06 »
hi ya ive got a mk2 8v with the mfa thing but it doesn work on miles or mpg it only works on oil temp and outside temp.
has anyone got any ideas, also how do i set the time.
cheers guys
Re: MFA wierd any ideas
« Reply #1 on: 02 July 2006, 22:26 »
sounds like the speedo sensor on the back of the speedo has gone, or the wiring to it is shot.  Quite easy to swap another one on there once the clocks are removed, theres a how2 guide in the maintenance + info section.
Offline gribsy2006
« Reply #2 on: 06 July 2006, 22:23 »
hi mate can you please give me more detail on this sensor, is it seperate from the clocks unit or part of it as i have another set of clocks. the oil temp and outside temp work on the mfa but nothing else.
thanks mate
Offline frog
« Reply #3 on: 06 July 2006, 22:47 »
Had the same problem concerning the mpg, turned out to be the black(?) vacuum sender unit that screws onto the back of the clocks (also check the vacuum pipe isn't cracked / split)
« Reply #4 on: 06 July 2006, 23:10 »
its held on the back of the speedo by 2 screws.  Its about the size of a small pencil sharpener, so if you can find one in your scrappy easily pocketable ;)
Offline bustersballs
« Reply #5 on: 07 July 2006, 07:29 »
oh yes how i laughed when i found £200 worth of parts nicked from our yard by a so-called VW enthusiast!!! i'd even made the wonker a cup of tea.
« Reply #6 on: 07 July 2006, 08:33 »
Wow he must have had big pockets! :grin:
Where did he hide the weighted shift rod ;)
« Reply #7 on: 07 July 2006, 19:12 »
theiving oik came for a headlight, told him to take one of a car down the yard, didn't notice how long he took, came back that night thro a hole he'd busted in the fence and helped himself, saw his car 2 days later wearing a lovely set of very familiar wheels,thats how! big pockets is one thin, the git must have bought a wheel barrow. half the stuff that gets nicked is worth very little, and i was no angel in scrappies in my youth(too old to fight alsations these days!),but seeing it from the other side of the fence has made me a bit ratty about it. especially as two weeks ago we had "visitors" who got 2 golfs started and played demolition derby at the front of the workshop, 1 freshly painted Mk3 wants spraying again,Mk2 8V written off, Punto written off by Golf (yeeee-ha!),same with a couple of customers cars. anyhow,rant over, would agree it sounds like the black doo-dah has gone pear-shaped. Oh,rubjonny, any ideas where the weighted shift rod should go if i catch me wheel thief? i was thinking more a drive-shaft.
« Reply #8 on: 07 July 2006, 19:47 »
Now that just aint on!  What a cheaky sod coming back later with wheels blatantly pinched off you  :angry:
I always make a point of buying summat whenever I go down my local scrappy though they do like to over charge for some things (£10 for the long gear linkage with the plastic ends!  Shame I was desperate and needed it that day :()
Make sure its the Driver side driveshaft  :grin:
« Last Edit: 07 July 2006, 19:53 by rubjonny »
« Reply #9 on: 07 July 2006, 21:33 »
hate it when they know you're desperate!!! needed an engine a bit sharpish once for a transit, ended up paying £100 then the week previous when we were just inquiring!
